jarekdadej
- Joined
- Jan 12, 2010
- Messages
- 21
I am in the middle of my mod now. the light is up and running already but i am waiting for AccuEvolution C and D cells and my Maha C-9000. The next thing i need is a nice alluminium reflector and glass lens. The lens is no brainer for me but i am looking for nice smooth or very low OP reflector with narrow beam pattern. I was thinking maybe Brightlumens reflector with 16mm opening but if you guys have better suggestions let me know. Next thing i am looking for is a driver with 30 to 60 miliamp output to drive the LED in "moon" mode. I was looking at DX but could not find anything. Thanks for your help.
Edit: Ok, i thought about it a little and came up with solution for moon mode driver and please correct me if i am wrong:
I will order this driver and remove 2 of AMC chips so that will leave me with 350 mAmps and then add small resistor in line to lower the current going to LED to anywhere between 30 and 60 mAmp. What resistor should i add? Will this work?
