Hi I am building a new P7 Mag 3D for diving. And hoping for some help. Here are some information about what I want to build:
- To be used for Scuba Diving
- Will saw the barrel length to suit batteries
- Looking for 3hrs burn time on 2.4amps (3 amps if it doesn't generate too much heat on land)
- Using a single SSC P7 CSXOI
- Will use sandwiched AMC 7135 with 16multi-mode driver as per StefanFS design here
- Will sputter the refector for an even flood.
My questions:
1) Is the Diameter of the D-cell Mag big enough to fit 4 nos. of 18650?
2) For 4 nos. of 18650 3000mAh I can have 4hrs of burn time on my P7 at 3A, am I right? (assuming the 100% efficiency for simplicity)
3) Will the stock Mag reflector melt if it is sitting on the heat-sink or too close to the emitter?
4) Do the drivers heat up or do i need to heat-sink the drivers?
Cheers
My questions:
Cheers
