wquiles
In a recent thread one of you here was cutting a very tough tool holder, and I even remember Barry saying something that in the past he has ruined some bits cutting some tool holders as well. Well, this is my story ...
I have plans to make a very rigid cut-off tool holder for my Iscar Do Grip cutout blade, the idea being that instead of having the blade being held in a block/holder, and this in turn being held in a BXA tool holder, it will be a single piece design.
Recently I scored a good deal on an used Iscar Do Grip grove/cut-off tool holder with the inserts (I really wanted just the inserts since the price was right), so I decided to "practice" making a single piece for my BXA tool post. Being a name brand holder I expected it was going to be tough, and unfortunately it was!
Here is the Iscar Do Grip tool holder on the left, with my Kennametal one on the right - note how massive the Iscar holder is:
Given those previous threads I decided to try my new 1" Toolmex Carbide cutter, held by my ER40 collet system:
It was a slow process, taking about 0.030" at each pass, but the cutter worked great:
It was also slow since I don't yet have a DRO, so I had to cut, measure, cut again, etc.:
Then, when it came time to work with the 3/4" 60 Deg HSS Cobalt dovetail cutter - everything went downhill, and the dovetail cutter failed miserably:
I had a second, brand new one, so I tried again, this time instead of a slow feed at 1000 RPM, I ran it at about 350 RPM - both times I was using the Kool Mist Clone pretty heavily:
This time, the new cutter, with the slower speed, worked much better, although the cutter is definitely dull now and the very sharp tips are gone (although not damaged like the old one):
and it did fit properly the first time:
Of course now I had to drill a hole for the adjusting bolt, and sure enough, my HDD drill bit just scratched the surface, and same for my premium USA 135 Deg Cobalt drill bits. Luckily I recently scored on a good deal on solid Carbide re-charpened straight drill bits, and those were able to easily cut through this tough holder (carbide drill bit installed on the drill chuck):
Here is a close up of the carbide drill bit:
Tapping was very, very slow, but I was able to get enough for a solid engagement. I now need to get a longer screw (3/8"-24 fine thread), and it will be ready for cutting duty:
To compare how much closer to the centerline of the carriage the new holder sits (less overhang), here the new cutter is flush with the end of the drill rod:
and here my Kennametal is about 1/2" further out:
Now I need to buy another 60Deg dovetail cutter, either solid carbide or with carbide tips, so that I can then work on my cut-off holder project ;)
Will
Will
