Any 6V Li-Ion batteries in 17670 form factor?
LightHearted
Fresno, California
Does anyone know if there exists a 6V Li-Ion rechargeable in the 17670 (2x123) form factor? I'm relatively new to the Li-Ion scene, and it looks like this would be the ideal solution for many regulated lights that run on 2x123.
Thanks,
Ken
:popcorn:
many regulated lights that run on 2x123 will run on an ordinary 17670 3.7V, some won't... If such a cell existed, we would know about it, and I have never heard of anything like that.
Actually it does exist. It is a 17500 with a boost converter mounted on the +ve end to yield an output of 6V. However, the runtime isn't too good on the 1100mAH 17500 with the boosted output ( efficiency around 65% ). Max. current is 1.5A. And it doesn't feature a protection pcb which is needed on running from a boost converter ( it will suck the battery dry without you even notice any dimming output ). Plus, it 'll need its own charger.
