Having read the manual last week, I remember that it has limit of either 3500 or 4500 MAH. I checked farther and it is the only factor NOT programmable !2) Have you tried charging C or D batteries? Can it charge it or there is a maximum mAh (like maha 9000)
Two questions :
1) Is the fan always on or kicks in incase of overheating ? How often kicks in?
Does it makes much noise? (i.e. can you sleep at the same room with the charger?
Got mine at www.rc711.com. These guys are just cool! Very fast and flexible.
Is this made in Taiwan?
Looks like OEM from Maha?
Two questions :
Thank you
It's like the fan on those old CPUs kicking in when you are doing some heavy processing.
The fan is purported to be "intelligent" and seems to just come on randomly. I don't know what algo it employs. Probably internal temperature. Afaik it's not configurable.
Specs | Maha | NC2500 |
Charging current | .2 to2A | 0.2-2.5A |
Delta Peak | ? | 3-15mV |
Discharge termination | 1V | 0.5-1V |
Maintenance charge | 10mA | 30mA |
Temp. protection | ? | 55-70C |
Input power | 12V 2A | 12V 2.5A |
USB power | none | 5V 1A |
Supported capacity | 100mAh-2000mAh | 500mAh-3500mAh |
Battery temp | NA | yes |
Battery int. resistance | NA | yes |
Battery volt graph | NA | yes |
Backlight | Always on | Off after 10 mins |
Firmware upgrade | ? | via smart phone |
Smart fan | NA | yes |
Bluetooth | NA | yes |
country origin | Taiwan | ? |
warranty | 3 years | 1 year |
default charge AA | 1000mA | 1000mA |
default charge AAA | 1000mA | 400mA |
Buttons | 4 | 7 |
One "major" difference I noted was the maintenance charge. |
