Anyone tried this light before?
never tried it. Probably makes a good around the house flood beam that's slightly brighter then a 1 watt luxeon, but it's nothing to scream at. I wouldn't buy it because it uses size "N" batteries.
I have nothing against n batts myself. They are quite abundant here...lol. And they aren't THAT bad as far as capacity.
It looks like a Led Lenser knock-off ( the V16 chipfire)
The Led Lenser uses 3 "C"sized batts though. I wonder if three "N" cells are able to drive it to full spec... /ubbthreads/images/graemlins/rolleyes.gif
HI.
It is a knock-off of the LedLenser V2-16Chip (got you Bart! /ubbthreads/images/graemlins/grin.gif) that is much bigger than this one (about 24cm total length) and uses 3xC-Cells in a stainless steel body.
Read more about it here if interested. It is much more expensive, too.
I do not think that 3xN-Cells could power 16 LEDs to full spec as Bart already pointed out, and the runtime would be ridiculous, too.
bernhard
EDIT: pics of the V2-16Chip
Hey B,
you are the LL expert here on CPF... /ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/grin.gif I'm just tagging along... /ubbthreads/images/graemlins/wink.gif
B@rt, this is just because you let me do it ... we know it ... /ubbthreads/images/graemlins/wink.gif /ubbthreads/images/graemlins/yellowlaugh.gif /ubbthreads/images/graemlins/wink2.gif
I like lights as much as the rest of you, But I just don't get the constant increase in led's per light. then to run them on N's, I just dont get it. I could make a 10x10 and run it on N's, for a few nims anyway. just my two cents worth.
jeff
WE know this is mostly an inferior solution.
BUT for the uninformed, a huge number of LEDs sounds very good, AND they are still cheaper than an LS AND you do not have to worry about the beam since the 5mm LEDs provide their own optix, it is much easier to do a light like this.
AND ... SF did it as well, think KL2 ... /ubbthreads/images/graemlins/grin.gif
As for the power source ... small cells for small lights, big cells for big lights ... but this combo with small cells in a big light is funny.
bernhard
I personally enjoy modding lights to use 5mm led arrays. They put out alot of light...I can experiment more because it's not that expensive to screw up...as opposed to the LS's. I can run 20 5mm on 3 D batts for quite a good amount of time. The 5mm leds are more versatile than the LS's ... they have no lens that easily pops off... /ubbthreads/images/graemlins/smile.gif
I agree for the number of leds in this light...n cells are not appropriate. Just wanted to see if anyone has tried this light before. I DO find n cells great for 3 to 4 white 5mm leds in 2AA flashlight bodies. At least for my purposes.
I totally agree. A few 5mm's are fine with N-Cells and can deliver quite a punch for a decent runtime. Anything more would be too much for the little guys IMHO.
Except for their well known flaws thiose two do this job quite well:
LedLenser V2 Triplex
LedLenser V12 Triplex
bernhard
