Stevie
Hi there,
Could do with some advice from those in the know.......I currently own a Myo XP but am not too happy with it (when the diffuser lense is in the down position, there is a lot of glare reflected down into my face).
To the point, I want a new headlamp and am having difficulty choosing between the PT Apex or the BD Icon. I have heard the following and could do with some clarification if anyone can help:
Will the Apex only run for about 1.5 hrs on high with regular AA bateries before dropping out of regulation?
Is it true that if you use lithium batteries this life can be extended to around 5 hours?
I enjoy night hiking and I would be annoyed if I had to change the batteries regularly.
I know that the BD Icon is not regulated. I have heard some tales that might put me off if they were true. These include the design of the battery pack being at fault, with batteries shaking loose at times. I've also heard that the build quality is not as good as the Apex. It is rumoured that the beam is not as bright, but in it's favour the light will last a lot longer on regular batteries?
Would much appreciate any confirmations / advice so that I can at last decide....
Thanks - Stevie
Thanks - Stevie
