Arc 4 turns on but wont turn off
delray
My arc4 will turn on but wont turn off (well it will turn off if I remove the battery). I have looked around a little and it appears that they had a problem with the switches but I did not see any solutions. Is there an option to fix this light or does it need to be thrown in the parts heap? Shame that this ~$200 light has stopped working. My $15 cree's are rock solid :(
Delray,
The highest probability is that the switch has been damaged. The switch can be replaced if you are handy with a small tip soldering iron. DigiKey.com sells the switches - Digi-Key part number 401-1951-ND, C&K part number EDM650AUSC0 LFG.
Henry.
