yclo
Who likes flood lights? I know I do.
I purchased an AAA sized 10440 Li-ion and charger with the intention of upgrading my Arc AAA to something better than the Nichia 5mm that was once bright enough for any flashaholic.
I used a XR-E emitter since the dome is tougher than SSC P4's gummy bear dome.
Bigger pic
Running at ~700mA with 2 x AMC7135 chips, the results are so amazing that I'm impressed everytime I turn it on. Here are some beamshots, the blue photon clone is actually brighter than the unmodded Arc AAA Limited Edition.
But, this mod wasn't done without sacrifice. An Arc AAA head was ruined in the process.
I had made up a can to fit the emitter/AMC7135's, but the blue arrow points to where the trouble started.
Bigger pic
As far as I knew, the Cree XR-E emitter only had contact pads on the ceramic board. And the board can only be shaved so small with bits of the contact pad still showing so wires could be soldered on.
Once I got to the smallest possible diameter, I started opening up the cavity in the Arc AAA head to fit the can. But I found out that the area where the o-ring goes can get really thin, this was after it broke into two pieces. See blue arrows below.
Bigger pic
So I made the second Arc AAA head cavity tighter, and all is good.
Are there contact points on the XR-E emitter that I could have used other than on the ceramic pad to avoid this in the future?
-YC
Bigger pic
Bigger pic
Bigger pic
-YC
