Yes, my shiny new, multicolored ARC-LS, with the special violet LS module, and the battery cases which do not conduct electricity to the light head died today, after less than 20 minutes runtime.
Just a day and a half after receiving it, and while still trying various steel washers, and small wads of aluminum foil to get it to approximate some level of reliability, my ARC-LS light module died.
I had compared the beam of the ARC-LS to my other LS flashlight, which I purchased for $25. The 3D cell conversion has a whiter, more even beam than the now dead ARC-LS had. The ARC-LS had a bit brighter beam, although a disgusting violet color, using the 123 battery case, or the 2AA case with lithium batteries, likely due to the fact that my 3D cell LS conversion has a light stealing lens protecting the LS module.
My only complaint is that the light is simply too expensive to do what I would really enjoy doing: seeing how well it holds up to repeated rounds from my S&W Model 29-2; a vintage late 1970's 44 Remington magnum, now reduced to the lowly status of 5th or 6th most powerful (production) handgun in the world.
Just as Robert DeNiro felt better after being advised to "hit the pillow" by Billy Crystal in the movie "Analyze This", I think I would feel *much* better if I could 'hit' the ARC-LS. Sadly, I can't afford this, as $105 is pretty expensive to be throwing away.
But it's pleasant to think about, plus the fact I no longer have to spend endless hours trying to make the damn light *work properly*, at least *some* of the damn time.
