[ QUOTE ]
McGizmo said:
Ty_Bower,
In the case of the Arc4, the switch is not a power switch but merely an input signal to the circuit that is always "on". I believe that part of the issues relate to using the battery to mechanically activate the switch while not interfering with the batteries closed circuit contact conditions. Poorly stated to be sure but the point I'm trying to make is that tail mounting the switch would require two leads which might be both independent of comonality with the Vin+ or Vin-. If the mechanics of such a feat were simple or even remotely attainable, we would see all kinds of cool light set ups!
[/ QUOTE ]
Actually, I think you put it rather well. Yes, I am aware the switch is not a "power" switch. Rather, it is a signal input to the smart chip in the light.
And yes, I agree, the difficulties are due to trying to use the battery itself to mechanically activate a switch at the other end. That's why I suggested if there were a way to put the microswitch in the tail, instead of the head, it would make it more reliable.
Of course, as you pointed out, getting the necessary number of electrical traces to the back is not easy. You've got one, which is the case of the light itself. To put the switch in the rear, you need at least one more. I best idea I've had so far is to construct the case out of two separate tubes, one inside of each other, separated by an insulating sleeve. Of couse, this adds to manufacturing costs. Even worse, if they somehow get misaligned, you've got a bigger problem than the one that exists now.
Peter's mechanically activated switch is rather clever. I'm just trying to brainstorm alternatives. /ubbthreads/images/graemlins/smile.gif
