brighterisbetter
I currently own a 1010 and two 1020's, all three of them with the 15 or 24 CR123 foam inserts respectively. But I've still got a whole bunch of loose new CR123's that I'd like to keep in somewhat secure semi-permanent storage. Rather than buy 3 or 4 more 1020's w/foam battery inserts, is there something else you'd suggest, like a bigger Pelican case for example that still has provisions for individual cells? I'd rather not have to mess with the pick-n-pluck stuff and just drop in a ready-made insert, for say 10x20 (200) cells, or even an 8x6 (48) would be sufficient if I bought two of them. Any ideas? I also have 6 Keep2Go tubes with 3 cells each stocked up.
Or if you've got a different method altogether then I'd be glad to hear that too.
