At least if the FLASHLIGHT is hot, it means its radiating heat..IE: Shedding the heat/keeping the guts cooler.
Part of the confusion about LEDs and heat, is that the heat is not being projected out the front the way it is with an incan....most of the heat is behind the LED for example. So it IS sending heat out with the beam, but, proportionally, much less than an incan would, etc.
As the science progresses, a series of incremental break throughs will, typically, lead to other break throughs. Someone will come up with a circuit, and some one else will realize that using that new type of circuit will allow him to do xyz...a prior bottleneck, etc. These things add up, and then, someone puts it all together and the industry surges ahead.
Rinse/Repeat.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So, sure, efficiency will continue to go up, and, the more efficient, the more power is turned into photons, and the less into heat...solving that issue.
The solution may even turn out to be a complete change in the way the light is generated...or, in the way the cells store the energy, etc.
Rinse/Repeat.
