Re: ARGH: Accident w/Amondotech 123s and SF M2 + Detonator + G&P Tailcap + Chop KL3 H
Addressing DonnyD (and indirectly, Ray_of_light):
Can H2O moisture exist within a lithium battery? I can understand the cells becoming assembled with some absorbed moisture, but wouldn't the H2O react out [with the metallic lithium] once the cell is crimped (and presumably "sealed") I put sealed in quotes, because there are many different levels of sealed. My educated guess is that the seal on a crimped (is there any other seal method on 123 cells) battery would consist of a polymer which is then crimped between the metal can and the metal top. This would act as an insulater to prevent short circuit. However, because you can smell a primary 123 cell, it obviously isn't a complete seal, I assume that the solvent used in the electrolyte is able to permeate this crimp seal. Hence the odor of CR123s.
It seems to me that any moisture that would be found in a primary lithium battery is going to react [with the lithium] upon manufacture, and the hydrogen gas from any reaction would permeate out the polymer crimp seal(assuming small quantities of H). Is this a safe assumption? Please Ray, can you elaborate on your battery chemistry knowledge? (I don't have a lot, I just have a little chemistry knowledge) I'm not trying to shoot anyone down here, I just want an explaination on how water can exist in a primary lithium battery. Any citations would be welcome.
