Hi all, I'm looking to cobble together a DIY bike light of some sort, but this will be my first mod/build, so I need all the advice I can get.
I have an Arc LSH-S that is cosmetically very beat up from a couple years of heavy use in Africa. To boot, the LED was physically destroyed when I dropped the light and it landed on its bezel.
I'm thinking of using the Arc as a host for a bike light. I'd like to drive a single Cree/Seoul via a board of some sort from an external 7.2V 2.4Ahr Li-Ion battery pack. I'll drill a hole through a non-functional kroll switch and install a female plug of some sort. I'll have the matching male connector on the leads from the battery. For my first go around I don't need an on/off switch, I'll just plug in the battery pack when I want light. I'd like to drive the LED at a minimum of 750ma, perhaps at as much as 1000ma. What board should I look at that will fit inside an Arc LS? At a diameter of 1", the bFlex will not fit in an Arc. A FluPIC would fit, but can't handle that voltage. nFlex is also too big. What else is there? I don't need multiple levels at this point (I'll save that for my next project!).
Anyone have any suggestions or guidance for me? I don't have access to a lathe or a mill, so fabricating any kind of metal part isn't a possibility.
I plan on mounting the light with either a thick o-ring a la dinotte or with a TwoFish LockBlock. This light will be for commuting on my 'cross bike in the city and in the suburbs.
Thanks for your help!
kermit
kermit
