First off, don't worry about the 4.17V charge termination on the Pila, this is going to be pretty normal for the Pila when used on RCR123 size cells as it's lowest current output of the constant voltage stage is designed around the higher capacity of 17500 and larger cells. It's going to terminate slightly premature on small RCR123 size cells. Consider it a blessing rather than a vice as it means your cells will never be overcharged. There is nothing wrong, especially if they are still holding ~4.17V the next day.
There is probably nothing wrong with your cells... allow me to explain:
When A LiCo cell approaches the point of being completely drained, the cell voltage starts to fall off very rapidly...
first click here:
http://www.candlepowerforums.com/vb/showthread.php?t=117117
have a glance at a few charts and get a feel for the way li-ion discharges...
If you see what I see, you see that the cell voltage runs a steady decline from ~4V down to around ~3.4V (all depending on load and cell size, so the numbers can vary some) under a load and then suddenly the cell voltage drops RAPIDLY to about 2.5V where tests are terminated, or where many cells would cut-off naturally with their built in protection.
All cells have some minor variation in capacity, but that variation can show up as HUGE voltage differences towards the end of a simulntanious discharge, because one cell will start to fall on it's face a few seconds before the other cell, causing it to drop in voltage rapidly, right down to ~2.5V where the protection kicks in and shuts down the circuit... while your other cell is still reading 3.6V...
The reality is that if you took that other cell, and ran it for about another ~10 seconds by itself in another circuit or something, it too would drop all the way down to ~2.5V under a load, and barely bounce back to ~3V open circuit. The fact is, that if your cells are staying within 0.01V of each-other through most of the normal portion of the discharge (which you have indicated) (where both cells are above 3.6V open circuit) then they are matched reasonably close in capacity and there is nothing abnormal going on here.
This is where it gets interesting. Today I checked the v`s, 3.75 and 3.76 respectivly. So I set my P3D to high and leave it on, about 10 mins later it goes off.
remember, 4.20V is 100%, 3.6V is basically dead. 3.75V open circuit means you had maybe 20% charge remaining, (give or take). So you got 10 minutes out of it... but I don't know what load the P3D runs at on "high" and are you sure it was "high" and not "turbo?" Assuming "turbo" that seems about right I think...
The only way to really tell for sure if your cells are "duds" would be to do a discharge test from a full. They should deliver in the ballpark of 550mAH if they are in reasonable condition.
Eric
