AW RCR123A in an Inova X03 (5.8W)
changcl
I'd like to use some RCR123A for my newer version of Inova XO3, with the 5.8W LED.
I've checked with AW and the answer was that the size would be OK but AW was not sure about the voltage since the battery puts out 3.7 V.
I've searched the web but I just couldn't find the answer.
Can someone help?
Thanks
I am also interested in the response since I also own the new X03 5.8W and know that 18650s won't fit in it. So I'm looking for a rechargeable option.
Edited to add... I just measured mine and it's a little less than 17mm wide, so 17670s are out too. I think 16340 is the designation for rcr123a. They should fit by the measurements, but I still don't know about the voltage so we're back to that.
I don't have any 17670 batteries to test that theory on the new X03.
Also, that's only 3.7-4.2V not 6. Will that work?
I use Ultralast 3.0 volt rechargeable cells in my Inova T1 with no problems. Protected 17670 cells won't fit. I would not use two standard (3.7 V) Li-ion cells due to the much higher voltage.
asdalton, are they 3V LiFePO4 or 3.7V with a regulator board on them that makes them into 3-3.2V?
How is the run time with them if they are LiFePO4?
How about a pair of 17500 cells? I use two to replace the normal three primary CR123s in my SL-TL3 incan with good results. I'm assuming the XO3 uses three cells as does the newer T3.
No, the XO3 uses only 2 cells. Strangely, it's the same length as the T3 (all versions), so there's some wasted space inside.
Inova bores its battery tubes pretty narrow, and I have not been able to fit a protected Li-ion cell such as 17670 into any of mine. The Ultralast cells are the exception.
Figuring out compatability with rechargeable cells on some of these types of lights can be difficult... here's some ideas:
1. AW sells a 14670 that would certainly fit- but I'm not sure what type of regulation, or lack of regulation the light has... so it might be reasonably bright still, or may be much dimmer, depends on various factors....
2. If someone with one of these lights, who also owned a bench power supply could do a few experiments, then we could find out for sure. The trick is to start around 3V, and slowly ramp up the voltage and see what happens. If it contains a proper buck regulator, then the current should reach a peak somewhere around 3.7-4.5V give or take, and then start tapering down as 6V is reached, if it continues to taper downward up to ~8V, then it can probably handle the rechargeable cells just fine, if it continues to ramp upwards steadily above 6V, or there is no current "peak" in that 3.7-4.5V range, then the light is probably not compatible with a pair of 3.7V cells. Disclaimer: even if the current does continue to fall as the voltage is increase above the 6V mark, there is no guarantee that the electronics can handle higher voltage, it may fry at some point during the trek to test the higher voltage input, anyone conducting such tests would need to be ready to accept the potential loss.
Until someone does a test like this, or is willing to test the current consumption with some higher input voltages compared to standard input voltages, then there will really be no definitive answer... alternatively, we could email inova and see if they would be willing to divulge some information, but most of these big name companies have no interest in opening themselves up to that type of liability.
Eric
I'm about to test RCR123s into my Inova X03. Just gotta wait till they fully charge... I'll let everyone know how it goes if I burn it out or not...
Sorry to bump an old thread, but hey, at least I use search. :thumbsup:
Quick question: since it seems that which batteries work in an X03 may depend on which X03 version you have ... how do you determine which version you have? I got mine quite some time ago and have no packaging, receipt, etc. I'm unable so far to find any indications on the light itself.
