The Kai light uses a nanjig 09 driver board which has two PCB's. The bottom PCB has the main boost converter electronics, and the upper board has a PIC microcontroller, and a small MosFet to provide the PWM switching control to create the different power levels.I got mine yesterday. KD CREE 5 Mode Single AA. I was initially impressed with the output and the 5 modes. Then after only 30 minutes and 4 or 5 cycles through the modes it broke and now i only have 1 mode. At least it still turns on in the high mode.
I sent KD sales department a sales question about the light and simultaneously sent their tech support department an email about my problem and only the sales department replied. :thumbsdow This was just a test to see if either would respond and determine if their office was open.
I didn't expect much for $15 but it's still a disappointment. If anybody has any experience with a fix or dealing with KD, please advise.
TIA
Sounds like the MosFet shorted, or your CPU crapped out on the upper board. This is what we refer to in the engineering biz as an 'infant mortality'.
I would ask Kaidomain to RMA and replace your light.
Kai has a convenient product return address in this country so at least you won't have to send it back to China [the U.S. address is in MIAMI FL, the full address is on their we site, but like any company, you need to get an RMA authorization first, so hopfully Kaidomain tech support will respond fairly soon].
For future reference, please also note that these Kai lights use fairly standard "Elly" style hardware and electornics, so if you are handy with a soldering iron and are worried about future problems, you can get a spare driver from DX for $3.50 (assuming that the head of your light is not too heavly potted with epoxy so you can get inside).
http://www.dealextreme.com/details.dx/sku.7302
My Kaidomain light is not epoxied, so I ordered one of the DX version drivers, because I noticed that the DX version specs a lower low mode than the one I am seeing on my light now (The DX version lists 100%, 35%, and 10% where I seem to be seeing something like 100%, 75% and 35% on my Kaidomain 5 mode light).
This may or may not work out because DX is a little spotty on tech info sometimes so it remains to be seen if the driver will actually have a lower low power mode or not (because it seems to be the same exact module used in the Kaidomain light), but the PWM ratios are set in software on the little PIC12F629 cpu on the board, and the manufacture (Nanjig) could have quite easily responded to the numerous complaints about the low not being low enough and changed the programming in the little CPU on this version.
Good luck, and I hope Kaidomain fixes this up for you as quickly as possible.
P.S.
By listing the driver, I am not implying that you should be stuck replacing it yourself, because Kaidomain should fix this up for you at this point, but for future reference, I wanted you to be aware that spare parts like drivers, lenses etc are readily and inexpensively available for these "Elly" style Kaidomain lights.
By the way, don't every try a 10440 style lithium cell (3.6 volts) in this light because it will fry immediately (the 1.5 volt Energizer E1 style lithium's are fine, if you can afford them).
P.S.
Just received it yesterday, for $15 its a steal, bar none. I like it better than my Fenix L2D-CE.
... in what universe?
Obviously, after the problems I've had with the light and the lousy support from KD, I agree!
In my limited experience, the only inexpensive high-power AA LED lights that have acceptable workmanship are from MTE. I have a number of these lights, with both SSC and Rebel LEDs, and they feel solid and are all going strong. I have 2 KD lights, one of which is nonfunctional, the other has been relegated to laboratory duties.
I'm not familiar with MTE. Do you have a link? After this experience, I am very reluctant to deal with Kaidomain. I have never received any reply from their support department. Only a request from Dora (sales) to ship the light back to Hong Kong. For a $15 light this isn't cost effective and furthermore, I don't feel I should have to pay return shipping on a defective light that quit almost immediately after arrival.
Try re-attaching to the wire to the screw, but with a metal grommet for better contact than solder.Anyone knows what this grey cable was for?
Is there any harm in removing it?
UPDATE: i got excited about fixing it too soon.
The light is still having flickering problems and does not turn on to full power.
I think the driver is buggered. sent kai an email let's see what they say.
Robo 21,
You don't have to pay for the shipping, usually they will give you credit for it. Either at DX or Kai. I have shop there before and that's what they did.
http://www.dealextreme.com/search.dx/search.mte
I own a couple of the 1-mode 1xAA SSC P4 lights, as well as a 5-mode Rebel100 1xAA one, and they are all pretty solidly built.
I prefer the 1-mode, simply because the 5-mode doesn't have a real low mode, and it's terribly inefficient at lower brightness levels, so there really is no good runtime gain. The regulation on these lights doesn't even come close to the quality of the Fenix circuitry, but at less than 1/2 the price, one really can't complain.
Mostly, whenever I shop at KD or DX, I just assume I am taking the risk.
