- Joined
- Nov 22, 2009
- Messages
- 236
I have a current rotary with a 18650 body. The light is acting very strange… And unfortunately unpredictable so I can't recreate the issue at will. The intermittent problems are so hard to solve.
FYI: Settings are factory (well custom set at HDS) and I have never fooled with them.
Problems:
1) The light will be on and I turn the tail and nothing happens…. No light output change.
2) Other times it will change but it is SLOW… like I turn the tail and it has to think it over then adjust the output. I estimate a 1-2 second lag.
3) I push the switch, hear it click, light goes on then shuts off. One press… on then off.
4) Light is on and I push the switch and it refuses to turn off…. It takes several presses to get it to shut down.
My attempt to diagnose I switched the heads (hi-noon/ SS40.. LOVE the SS40) and the problem occurred with both heads using the same 18650 body/tail switch.
I switched the battery and it has occured with two different batteries. The batteries are not dead when switched… they will still go to high and hold, NOT stepping down quickly as when primaries (123) start to die.
Cells are the ones HDS sales.. Sanyo NCR 18650GA
Sometimes it will run perfect for a week or so of daily use then suddenly start acting up.
I am a LONG time HDS user…. Never have I had this behavior. Actually all my HDS lights have been rock solid. However like anything you really depend on I always carry two. I am beginning to not trust this light / battery combination.
I suspect it is the switch in the tail. Or could it be the rechargeable batteries? I have a little experience with them and understand they go dead quickly and unpredictably at times in other lights.
Anyone had similar behaviors with a 18650 tail.
Problems:
