You guys have lost your minds. Using in parallel is fine. Charging is not.
One pack will always peak first. Then its voltage drops. Then it starts consuming even more of the current, so that the other pack never peaks.
Overcharging is the result on a good day. Cell venting and/or rapid expulsion of the internal parts happens on a bad day.
Even if you get *really* lucky and the charger shuts off when one pack peaks, you're missing out on achieving full capacity on the other pack.
I've blown up enough packs (and cleaned up exploded cell parts) to know about this in detail.
