I have recently put together a torch using a lumens factory 18650 e series body which states only single wrapped unprotected batteries may be used.
I had some unprotected batteries that appeared to be double wrapped, a clear wrap over a red wrap underneath. They did fit inside the body double wrapped but with zero wriggle room, so I removed the outer wrap no problem.
But once I removed it it left the edges of a white disk surrounding the bottom top exposed that appears to be stuck on but is lifting slightly on one side.
I am worried if I remove this disk there will be nothing surrounding the button underneath or that it is part of the button that will come off with it leaving a flat top.
As it is with the edges exposed as they are it looks like I have left it vulnerable to damage.
Should I remove this white disk.
Leave it be, or should I not have removed the outer wrap in the first place?
