Jaybird
- Joined
- Feb 19, 2009
- Messages
- 55
Hey all,
I wanted to ask a question to the fellow flashaholics about their routine battery maintenance. I know the topics regarding chargers and batteries in various threads has been stripped, analyzed, recorded, disassembled, put back together, and eaten alive already <grin>. I've done my best to try and read them all but what I've failed to really find, and what I believe lots of people might be looking for, is how should I maintain my cells on a regular basis.
Once again, I know this is an open ended debatable question but I'll explain what I have, the routine I've put together, and then I'd appreciate any comments or deviations that other people may suggest.
Currently I'm using the C9000 charger with Duraloops all around (both AA and AAA's).
From what I've gathered in various threads and from the C9000 manual... this is what I have been following (assuming starting from a new pack of AA Duraloops):
Charge 1: Break-in (1-3 times).
Charge 2-9: Regular charges (at about 1000ma)
Charge 10: Refresh & Analyze
Charge 11-19: Regular charges (at about 1000ma)
Charge 20: Refresh & Analyze
Charge 21-29: Regular charges (at about 1000ma)
Charge 30: Break-in
<rinse and repeat from charge 2 again after charge 30 depending on battery performance>
Is this a general good schedule to follow? or should there be any deviations from this? if so, what do you recommend?
I'll just add that I've developed a little Excel spreadsheet to accomodate the above schedule with inputs for Mah and voltage readings at certain intervals to keep track of the battery performance.
Thanks ! :confused:
Charge 30: Break-in
Thanks ! :confused:
