Battery Passes Urine Test, Running 90 Minutes On Pee
Of course, the pee does not provide the power. The pee (or whatever, you could use salt water or soda) is just the electrolyte.
The power comes from the two chemical reactions between the electrodes and the pee. The secret are the electrodes. One (or both) will be used up. When this has happened, peeing on it won't help, which would be real pee-powered.
problem with pee is the plates [in this case contacts] will have a thin sheet of sediment on it....it isnt exactly premium electrolyte:ohgeez:
