Has anyone tried these yet? Will they actually fit into a Mag tube? Are they worth the price?
Thank you
Thank you
Hi Mudman,
I could have used the LiFePO4 D cells but wanted the max runtime. Thus I'm using the F size cells (1.5 D cells in size). The Ah rating is a little better than the same LiFePO4 D cells. I'm hoping that four F cells will fit into a 6D Mag.
At nominal 3.2 x 4 = 12.8 Volts my 64625 lamp should really pump out the photons.:twothumbs
