I have many packages of AA Duraloops (white-top LSD Duracells manufactured in April '09) that I just recently opened.
When I put 4 of them in my La Crosse BC-9009 and set it to charge at .5C (1000mA), the charger momentarily pauses charging on a couple cells towards the end of the charging process. All the cells are also very hot to the touch, to the point that I can only hold my finger on them for a couple seconds. I have tried this with multiple packs, and it happens on all of them. It also happened with older non-LSD Rayovacs, but I figured it was caused by the old batteries and didn't expect it to keep happening when I switched to the new Duraloops.
Is this normal, or might it damage the batteries over time? I can think of several ways to handle this issue:
1) Do nothing (if it poses no real problem)
2) Direct a fan at the charger
3) Reduce current below .5C
4) Limit charging to 2 batteries at a time (although this is significantly less convenient)
Thanks for any advice!
