Beamshots: M@g SSC P7 vs Penta Cree Q2 M@g vs M@g 623
rizky_p
13th Colony
I was bored so i did this, old stuff but hopefully still enjoyable :)
Mag SSC P7:
2D body
DHS Heatsink
KDs 7135 2.8A driver with 5 modes.
SMO Original Reflector
5AA Sanyo 2700
Glass Lens
KD's CSWOJ SSC P7
Penta Cree M@g
3D Body
10 Sanyo 2700
Maxflex Driver
Glass Lens
5x DX 18mm OP reflectors
Download's Multisink
5x DX Cree Q2 WC LED
M@g 623
D body
Luxluthor's 15.6v 13 cells battery pack
Kiu's High Temp Socket
KDs OP Alu. reflector
Boro Lens
Osram 633 Bulbs(instead of 623) but i still call it 623 :sssh:
Fenix T1 as a baseline. :candle:
SSC [email protected]
Penta Cree [email protected]
623 :eek:oo: :oops: overexposed.
Different place
SSC P7
Penta Cree Q2, i accidentally moved the camera :oops:
623
Thanks.
risky_p,
Thanks for sharing those cool beamshots:twothumbs. The TK1 has no chance against those Mags. Do you have estimate runtimes to compare for those lights?
I'm building a Mag623, Mag1185, and have completed a Mag P7. I may have my lights together by the end of the week and like you, will show off my beamshots then!
Thanks for sharing!!!!
That was a beautiful garden before you turned it into a scorched desert with that Mag623! Very nice pics.
@uluapoundr:
Mag P7 battery draws: H/M/L = 2.8A/1A/0.5A
Penta Cree Q5 battery draws L5/L4/L3/L2/L1 = 3.2A/1.42A/0.67A/0.31A/0.06A
Mag623 runtime is less then 10 minutes i think.
Penta cree measured using slightly discharged battery pack so the figures are higher than when the battery is full.
Estimated runtime using the above values:
Mag P7 running at High around 1 hour, Low around 4 hours
Penta Cree at Max(L5) is less then one hour, Low(L1) probably around 40 hours :)
@DM51: Thanks, my favourites are always the "Sisters" that trees are just like twins and almost have the same growth-curves :) Amazing dont you think?
I guess what this test shows is that if you need less than 10mins of runtime then the Mag623 is the way to go!:crackup:
Yes and also ALOT of heat :) you cant barely use 623 more than 1 minute at a time. The head will get hot real quick, . :devil:
