Hallis
Well it's been a while since i've been on the forum. Hope my old friends are doing well.
Here's the scoop. I've got one of FM's cut-bored-finned-coated-awesomed D size hosts from way back. It uses a 6xCR123 adapter putting 2 stacks in parallel giving 6v, or 8.4v if using rechargables. Right now the business end is all stock hardware but i put in the little 4 cell factory Mag LED module in it. so stock switch, cammed plastic reflector, etc.
Recently my brother brought home from Wal-Mart a rather heavily constructed and durable as hell 2D Eveready flashlight with an LED in it that was insanely bright. I couldn't determine what type of LED was in it. As I imagine that the list of manufacturers, modules, drivers, etc. has grown quite a bit since the last time I was around these parts I'd like some input about what you guys would build.
I'm not looking to set fires or suck these cells dry in 5 minutes. I'd like to get about 2-3 hours of regulated runtime on primary cells so 6v. I don't need multiple brightness, would like to retain the original click switch. I've got some basic soldering skills and have installed a heat sink way back in the way when i build my own Mr. Bulk Space Needle clone.
Fire away gentlemen. :)
