Before I purchase...
kuksul08
California
Does this look like it'll work?
The only questions I have are regarding what size potentiometer to buy. I went to the store and they have anywhere from 500-50k ranges, and wire wound/cerment varieties.
Also regarding forward LED voltages. I have an SSC P4 in a headlamp and when running at 330mA its Vf is 3.02V. Isn't that kinda low?
Thanks
The forward voltage of the SSC P4 depends on which bin you have.
I believe most are in the 3.0 - 3.25v range, but there are some that are in the 3.25 - 3.5v range.
Hmm, so it's kinda hard to tell exactly then.
How about my other question?
Also what size wire should I use? I was thinking 20Ga stranded to be safe.
Not sure about the potentiometer. I just use resistors for the stuff I build with 5mm LEDs.
I bought 24 guage stranded wire for my projects.
But now I need to get a new wire stripper since mine can't deal with 24 guage :ohgeez:and using an X-acto knife is a pain.
Thanks for the help :)
It's pretty confusing. Maybe I will first just buy a few parts to play around with before spending more money on a big project :)
Couple more questions...
My goal is to build a bike light that I can attach to my helmet or handlebar. For now I will be using two LEDs in a custom aluminum enclosure. I was planning on using P4's, but would the cree XR-E Q5's be a better choice? I don't know much about them.
I will be using this homemade circuit
from this instructable: http://www.instructables.com/id/E7QH8NG8I1EWOF32HJ/
I think I will run them at 700mA but I'll see how hot they get.
I just don't want to mess up here
Well crap... I went out and bought the parts to make the driver and it burned out my LED. With a 4.8V input it put out 1A, and with 7.2V input it put out 5 amps! I should have checked it first... the led turned blue and went out pretty quick.
Guess I'll just have to buy some DX or buckpuck driver now... :(
Your first diagram shows the AMC7135 driver.
Were you using that, or is that a driver you had planned on getting from DX?
The first diagram was my original plan. I then made my own driver using the second schematic, and as it turns out I wired it wrong. Once I switched one connection it gave exactly the current I specified. doh!
