Phaserburn,
Yes, both voltage and current, and hence power, are increased a little. Because there are two strings of batteries, each battery supplies only about 1/2 of the current it would otherwise deliver. Because the current is less the voltage drop is less. I have measured the voltage of a 123 cell to follow a relationship which is closely approximated by:
V = 3.0 - 0.3 * I
This relationship is good for currents between 1.0 and 2.5 amps through the cell. Let us assume a SN II on 3x123 draws 2.0 amps. The voltage output is:
V = 3 - 0.3 * 2 = 3 - 0.6 = 2.4 volts per cell
If we add another string of 123s, then each string will supply only about 1.0 amps, and the voltage is now:
V = 3 - 0.3 * 1 = 3 - 0.3 = 2.7 volts per cell
The added voltage will actually increase the current a bit to perhaps 1.1 amps such that the entire current draw is about 2.2 amps.
The run time will be approximately doubled.
It's a good question you ask because 2 strings of 123s can be fit in a Mag D. /ubbthreads/images/graemlins/grin.gif
Paul
