AncientSword
Hey guys, I am a noob with incans and I just got a mint Surefire A2. Its output is a little less than I would like, so what can I drop in it to bring it to life?
Dang, I did not know it was regulated.
the main reason why its price so high is the regulation, known only to a handful of lights in existence that has regulated incandescent capability. The good thing is whether your batteries are 100% or 40% you get basically the same amount of output, rather than white for 100% and orange for 40%, the down side is there is very little upgrades you can use because the output power is fixed by the internal regulator
Thanks for correcting him, I was about to post the same... The Strion lamp is NOTICEABLY brighter than the stock lamp.That's wrong. Output power is NOT regulated. Output voltage is regulated.
Power=Voltage*current
Regulator can tolerate some higher current. Strion bulb pulls about 1.8 Amps while stock bulb pulls about 1.4 Amps in A2
Please see DM51's Strion revew.
In the meanwhile, you should really try the HO-A2 from Lumens Factory. It is brighter and whiter than the stock MA02 but it won't kill your batteries as fast as the Strion lamp...Hey FM, I was hoping to get one of your kits for the Strion, but it appears you are out of them. Is that correct?
Glad you guys brought up this topic,is there a lamp for longer battery life even if its not as bright as the stock lamp?
Not that I'm aware of. At least I've never heard of such a lamp. The A2 lamp is kind of tricky to make from what I understand, so Surefire and Lumens Factory are the only ones who have made a version that I know of.
Apparently Surefire mentioned in one of their old catalogs that the A2 was going to have an optional MA01 lamp that would put out 25 lumens for 130 minutes. It never saw the light of day but it would be nice to have. Maybe Lumens Factory could make one?
I'd definitely buy one of those if LF put such a bulb into production. I love the HO-A2 in my A2. Compared to the stock SF bulb, it's brighter, whiter and gives a smoother, more round beam.
