Bizarre D36 lego (w/ pics)
Benson
I was browsing Lighthound the other day looking for stuff to make the $75 threshold for free shipping, and saw the Wolf Eyes 6MX incan drop-ins on clearance for $2.99 a piece. I'm not much of a low-power incan guy, but at that price, it seemed worth a try -- if I can make them fit in something, and I like the result, I can always go for an LED drop-in later.
So I started taking my collection of (mostly "budget") lights apart, looking at bezel and head sizes. (Incidentally, the Ultrafire WF-008 was a near-perfect fit, but I liked the existing LED/recoil reflector much better.) Turns out that a Northern Industrial 2C I had about is quite a nice fit. (Notice in the second picture that the bezel's just a bit oversize -- with the lens removed, the drop-in would barely rest on the lip.)
Now with a 6V bulb, that 2C body wasn't exactly a perfect fit -- way oversize for 2 CR123s or 2 AAs (whether lithium primaries or LiFe), and not quite big enough for 2 A123 26650s even if I had them. So that body's on hold till I get a 9V module for 2 25500s. (Yes, I know ultralife makes C-size 3V primaries. I've no clue where to get them, or how much they cost, but I'm not a big primaries guy anyway, and I'm sure they're much too expensive for my taste...)
But I also had some previous experimentation with comparing threads on random flashlights in hopes that something useful would fit. I know that an Ultrafire C308 has the same head threads as the Northie, but the C308 (originally an 18650/3xAAA light) has the pill in the body, whereas the Northie has it in the head. With the pill removed,the body's long enough for 2x 18500s -- of course, again, we run into the voltage problem, but this time it's a close enough fit that I was able to get it together and running on 2 IFR14500s from Walmart. White, bright, and usable enough. But that reverse clicky, and the insanely oversized body for only 1.28 Wh of battery... :sigh:
Enter the SacredFire NF-007. Despite the bizarre brand, it started life as a very handy AA/AAA/CR123/17500 light. The bezel and pocket clip got lost somewhere along the way; it was just sitting in the parts bin. I'd already made the discovery that a McClickie fits perfectly in the tailcap, though, and it has the same threads as the C308's pill. Remove the C308 body while leaving the pill/head adapter...
And add the NF-007 body and McClickified tailcap. That little 17500 body, plus the extension given by the C308 piece, holds 2 CR123s, making a perfect 6V. (After the whiteness off 2 LiFe cells, this is actually a bit disappointingly yellow. Reminds me of everything I don't like about incans for <1000lm builds.)
But it's cute, fits in any pocket that any D36 host could fit in, and has a lovely forward clicky. I may wind up pruning the bezel a bit, but I can see this with a 17670 (and appropriate LED drop-in) moving to my jacket pocket for good.
And in case anyone was wondering about those exposed threads...
Yes, the C 308 body will screw down over the NF-007. In lieu of a lockout tailcap, or to tailstand, but mainly because I was curious if it would.
Wolf Eyes parts have always been somewhat Lego'able, and became all the more so when the company introduced extenders to make their Rattlesnake 3x18500 (3x150A) and 3x18650 (3X168A). But this is the first time I've read of someone successfully using body parts from another make. Thanks for taking the time to try these variations and to share your findings in words and photos.
By the way, the 6V (nominal) xenon lamp may be in store for a renaissance, thanks to 2AA, 3AA, and 4AA (via 3x18650) bodies and NiMH and NiZn AA cells that deliver decent voltage under a 2-amp load (1.2V and 1.6V, respectively). I'm awaiting receipt of four high-peformance D26 xenon lamps from Lumens Factory that will deliver 150 to 200 lumens of real, broad-spectrum light at 3.7 to 4.8V under load. I'll be testing these in my 2AA, 3AA, and 4AA bodies, using Eneloops and NiZn AAs. My findings can be found in the Incan forum, in a thread I've begun about incans and AAs.
You have way too much free time, you need to get out more :nana::nana::nana:
