This will be a short/incomplete review, and mostly a heads-up for anybody who is looking for a good bang-for-the-buck spotlight.
Also...apologies ahead of time for the poor beamshots (and lack of outdoor beamshots), as I don't currently have time to learn all of my camera's settings.
Got this light at Walmart for just under $20. Since it came with 4C batteries, it actually costs $16 (it comes with Rayovac batts that go for $1 each or so).
It has 2 modes.
100% output, 130 lumens, 20 hours runtime
20% output, 40 lumens, 78 hours runtime.
*I would have expected the low output mode to have more of a runtime advantage over the high mode than this.
It doesn't say if these times are regulated, so I'd guess not. Even so, it should run awhile on 4C's. With that said, I would have preferred D batteries, which I can usually find for cheaper, as well as them having double the runtime at the expense of size and weight.
Overall build quality is good, especially for the price. The LED's are not perfectly centered, so I tried to find the best one. The trigger is fairly hard to press and is not pleasant to use. Also, this light requires you to go through both modes before you can turn it off: high-low-off. It's a reverse clicky. As you'd expect with a spotlight, the reflector is quite deep, with stippling near the LED, and a smooth portion composing the rest.
You can't tell from my beamshots, but the hotspot isn't perfectly round; this of course only matters on the white wall, and would not be noticable in practical use. The beam is mostly concentrated in the hotspot, so while it has good size spill, it isn't very bright.
As for the fact that it takes C batteries: I prefer a spotlight that takes alkaline batteries, because all the spotlights I've had with rechargeable batteries have had the batteries go bad within the year. I admit I didn't "take care" of them by charging them often enough and not letting them go completely dead. With this light, I don't have to worry about that. Now, if you use a spotlight more than occasionally, you might want one that has a rechargeable battery.
Conclusion: Despite its faults, I think it's great for the price. I much prefer this to a halogen spotlight with an underpowered SLA battery and a runtime of 20 minutes that I could get for the same price.
Pics:
*Spotlight on left (low mode, 40 lumens), Olight M20 on right (medium, 90 lumens)
*Spotlight on left (high mode, 130 lumens), Olight M20 on right (medium, 90 lumens)
*Front of package
*Rear of package (due to low resolution , you may not be able to see distance claims: 190 meters on low, 336 meters on high)
*Claim of runtimes
*Reflector
It has 2 modes.
Pics:
*Front of package
*Claim of runtimes
*Reflector
