FRITZHID
is there a 6v to 12v 8A boost driver available? i'd prefer it to be over built and last, doesent need to be uber regulated but durable more then anything.
It is certainly more expensive, but you can use multiple boost drivers to achieve the total power output that you need. So for example, lets say that you have 10 LED's that need driving, you could use one boost driver for 5x of them, and a second boost driver for the other 5x. The input to both boost drivers would be connected in parallel - both drivers would get their input voltage/current from the same source, but you would split the work, instead of having a single driver try do all that work.
Will
a client of mine wants to upgrade the headlights on his show car, that has a 6v system, to HID. i've already done the tail lights and marker lights in LED, as well as the interior and dash lights, but with the color scheme of his lighting, he wants a bright purple for the headlights, and i can't find 6v HID ballasts. he wants to keep most of the system at the stock 6v. and has all the stock parts set aside so he can sell it as stock should he decide to, but until then, he wants to mod up for the showcase.
