Is the brass coated to prevent corrosion?
This shouldn´t matter with this particular light since tailcap has a clicky switch and the battery is inserted from the front end of the body. But I´m with you in general.THe only thing I don't like about it is having the clip on the tailcap just because like the novatac/HDS it rubs against the body when you rotate the tailcap to remove.
