Brightest LED??
jawnn
a funny farm near Seattle
What is the brightest LED????
I thought the SST-50 would be but the first tourch that has it is only 500 lumins.
So is the SSC-P7 it? untill they make a quad die out of the XP-G????
The brightest single die LED is the SST-90, not the SST-50.
http://www.candlepowerforums.com/vb/showthread.php?t=224644
2250 lumens at 9A.
For a single LED torch:
The Blaster NG (SST-90) 1750 lumens:
http://www.cpfmarketplace.com/mp/showthread.php?t=199637
If you scroll down to post 16 you can see the Firesword IV with 4*MC-E is brighter at 3000 lumens
Firesword IV link:
http://www.cpfmarketplace.com/mp/showthread.php?t=187587
The brightest LED torch?
Kong 12, 8600 lumens Link:
http://www.cpfmarketplace.com/mp/showthread.php?t=196135
If you are going swimming/diving with it, it might be better to contact a high end dive light maker such as Barbarin.
elektrolumens does custom work and he has always wanted to make a dive light so post in his subforum at CPFMP or contact him directly at
[email protected]
Water is better at removing heat than air so no additional cooling fins are needed. Waterproofing the light is the hard part.
effeciency
what is the max lumins the sst-50 and 90 would do at a lowtemp like 77f and what wattage?
my goal is 1200 lumin work light w/30-40 degree beam that will run for 4 to 6 hours on a portable battery.
