Brightest straight-body 2xCR123 light?
KQL
I've got the EagleTac D25LC2 with the Nichia 219B emitter, but I'm craving something brighter. However, I REALLY like the straight tube design where the head is the same diameter as the body. Their XM-L2 version puts out 620 lumen, but I can get almost that from my Sunwayman V11R running on a 14500.
So, if my V11R can put out 520 lumen at 4.2V, are there any straight-tube 2xcr123 lights than can put out more using the higher 6.4V from the two primaries?
TEEJ
NJ
The CR123's are your limiting factor, as they are hard pressed to maintain that kind of draw. If you went to IMR 16340's, you could bump up the performance. The run time on CR123's is going to be short at the actual max output number.
GordoJones88
Tennessee
Wouldn't the light likely have some sort of a buck circuit bringing the voltage down anyhow?
Joeymt3
Have you looked at the fenix PD35? 850 lumen stock. Runs 18650 or CR123's. I got a custom one from Vihn and it is crazy bright on one 18650. I haven't tried it with primaries yet. It's around 1400 lumens.
KQL
Great suggestions, thank you. That PD35 sounds great, I don't see it on Vihn's list of lights, was it a special run? (Edit: found it) Are standard 18650's capable of running it (I have some EagTac 3400's), or would I need higher draw IMRs? Other members of the household use these lights too, and I want to keep the number of precautions I'd have to communicate to them to a minimum.
Watching my wife's eyes glaze over while I was explaining the Zebralight interface to her, now that light only gets used by me. That's a win-win I guess.
I hate to be nit-picky, but both the PD35 and the P12 are an inch longer than the D25LC2, but might be worth it for the lumen bump. Are the stated lumen levels (PD35=850,1400vn, P12=950) using the ANSI standard?
Boy, that 1400 lumen PD35 sounds nice.
Dan FO
FL
Regular 18650s will run the PD35 just fine. Your 3400s will do the trick. It is supposed to be 900 lumens on 2 CR123s. I really like mine!
KQL
To be clear, I was asking if EagTac 3400 would run the modified 1400 lumen pd35. But I'll just reach out to Vihn.
Fireclaw18
Mountain Electronics SSSP is pretty bright for a pocketable straight-body light. It's a modified Convoy S6 with triple XPG2 at up to 6 amps. Around 1500 lumens OTF.
It doesn't run on 2xCR123 though. For max possible output run it on a single high-drain 18650 cell like a Samsung INR 20R.
Entire light made to order including all the mods preinstalled is around $60.
KQL
I placed an order for a Fenix PD35 this morning from REI. I considered Vihn's modified light, but in the end I like being able to use the cr123s if needed, not just 18650's. Thank you everyone for the input.
Ryp
Any particular reason you chose the PD35 over the P12?
KQL
1) I have several Fenix lights and have been happy with them.
2) SelfBuilt's comments on quality of "feel" in his comparison review.
3) I have a local REI that I can return the PD35 to if it doesn't suit my needs.
4) The biggest complaints with the PD35 that it a) doesn't tail stand and b) doesn't have a low-low mode don't figure into my projected use for it.
5) The PD35 has been measured to be around 950 lumen, so that's a wash with the P12, and the TN12.
6) After being disappointed with the quality of my D25LC2, my first EagleTac, I wanted something that will just work out of the box, instead of taking a chance on a new-to-me brand.
In fact, the TN12 was my runner up choice, and I may still get it as an extra light in the future.
Ryp
REI has the P12, and it's $15 cheaper than the PD35. It also throws farther than the PD35 and can tailstand. The ~100 lumens between the 3 lights will barely be noticeable, and the P12 has a battery voltage indicator which none of the other 2 lights have.
KQL
Didnt realize REI carried Nitecore. And sure enough, my local one has them on hand. Will definitely check it out first hand next time I'm there.
Charles_Jacques
Does anyone have a phone number for Vihn? I am interested in his mods for PD 35 or Army Tec Barracuda, my 2 new lights. Only want to mainly use 18650s w 26 or 34 mah. Thanks.
Charles
