liketotallyrandom
What is the brightest, non-custom light under 100 grams (3.5 oz) INCLUDING BATTERY? Bonus if it's floody and/or a neutral tint.
Zebralight H60w is neutral tint, 100g with battery & headband (77g w/o headband), and runs for 10 minutes on max before dropping back to high.I'm really looking for a VERY floody neutral tint, because those cooler tints often get absorbed in the redish mud of Alabama caves, eh. What I seem to need is a neutral-ish MC-E in an undersized host good for only running about two minutes at a time due to thermal issues...
Interesting. I missed that one somehow. It's lighter than I thought. The Quarks aren't really floody enough, though. They seem floody enough for many tasks, but I need a mid-range beam (10-75 feet in range) halfway between a Zebralight 501w and a JetBeam Jet-I Pro Q3 5A.
Quark 123^2 XP-G R5 + 17670 should manage that.
240lm OTF
When using scotch tape diffusers, don't use the matte finish, but specifically the "satin" finish. It diffuses the light with much fewer losses.
I was thinking "Sounds like a job for Milkyspit" a highly-respected CPF modder. He has a few small single cell [18650 I believe] MCE [or P7] lights that put out a ton of lights. He may be able to build the perfect light for you.Nevertheless, thanks for the input. I was just wondering if I was missing a good factory-made solution, but it's starting to look like a custom built solution is called for here...
