ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I found this at Walmart for $19.99.
Uses a 3 Watt Luxeon. The beam is nice a white. Has rings in the beam. Does not have a very bright side spill.
The Brinkman does not have a rotating head to adjust the beam.
Momentary on constant on.
Fit and is good.
The Lens Bezel has machining marks.
The Type II Anodize is good. Maglite does a little better job.
Plastic lens and reflector.
Lens size is 50.89mm or 2.003".
I really like the Brinkman 2D.
It does not run into the problem like a Maglite using a Magled Drop In. Heat Management issues, loss of brightness. The Brinkman stays bright.
It's cheaper than a Maglite with a Magled.
I will probably mod the Brinkman 2D 3 Watt Luxeon in the future.
No thermal paste or Artic Alumina.
It looks very easy to mod.
The reflector is a lot shorter than a Maglite reflector.
This is where the +ve battery anode makes contact.
Size comparisons.
Left, Brinkman 2D 3 Watt Luxeon. Right, Maglite 2D with Magled Drop In.
These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I used Radio Shack D Nimh Batteries 1.2V 4500mAh that were fully charged.
Brinkman 2D 3 Watt Luxeon - 5670 lux @ 1 meter
Maglite 2D Magled Drop in - Initial reading - 3290 lux @ 1 meter. 2 minutes - 2600 lux @ 1 meter.
Brinkman 2D 3 Watt Luxeon @ 87"
Maglite 2D Magled Drop In @ 87"
Left, Brinkman 2D 3 Watt Luxeon. Right, Maglite 2D with Magled Drop In @ 87"
Left, Brinkman 2D 3 Watt Luxeon. Right, Maglite 2D with Magled Drop In @ 87" Stepped down exposure
In time the Maglite 2D with Magled Drop In will loose brightness due to the Heat Management issues.
Fit and is good.
Size comparisons.
