How do you use a broaching tool, like for cutting keyways? Are they really effective?
Is it as "simple" as it seems, just pushing down on the part & it just cuts with the down ward force as you advance the work piece in small increments? What about for harder metals like steel, seems like deflection of the tool would be an issue causing alignment issues while cutting or even a taper?
Could they be used in a drill press assuming a vise with a cross slide is used or is a mill absolutely necessary?
