Buck/Boost driver question
Th232
Sydney, Australia
I've been looking at various driver circuits recently, and maybe I just haven't been looking in the right places, but while I've seen a fair number of buck or boost drivers with varying input and output voltages, I've seen very few buck/boost drivers, and those that I have seem to be centred around CR123As.
I've been playing around with building my own lights, and what I'm after is a buck/boost board that will be suitable for using either 2x CR123A or RCRs, or 1x 18650, but also 1x CR123A in case I want to use the driver for another light as well. If it was just 2x CR123As or 1x 18650, I'd just go with a buck regulator, but I guess I'm just attracted to the versatility of such a driver, if it exists (partly because of the AUD=>USD exchange rate).
At the moment the only solution I seem to have found is using a buck regulator and either let it go into direct drive for using 1x CR123A, or buy a different regulator for it (the GD comes to mind). If I go the DD route, is there anything in particular (heating issues?) that I should watch out for?
Reusing the board for another light (and with a different battery pack) is nothing but a thought at the moment, but I figured it'd be good to see what's out there (if anything). Is there anything inherently stupid with any of the above thoughts?
Hi Will,
Your request is perfectly logical, but you are right, there are very few options out there - perhaps none that actually will work. At least I could not find any now or in the past.
The closest I could come up with is this one from the sandwich shoppe
http://theledguy.chainreactionweb.com/product_info.php?products_id=1106&language=
It basically covers the entire range of 1 cell, primary or R. I have either this one or a similar one in a light I own driving a r/o Lux III, but also it can drive various single die white as well.
At one point in time, I looked at having a custom board made which would deal with your exact request. The main problem is that the components that make sense to use in a buck / boost setup typically didn't come in the input voltage that also makes sense. (have not looked lately).
The EE I was working with suggested that we could take "any input voltage" - boost it up to a new "fixed voltage", then buck it back down for current control. While this would likely work, it also would have considerable losses (2 conversions) and be rather large - so it didn't happen.
It is possible to make a light which uses your battery configuration, but not exactly universal. The basic idea is that you buy an LED package that has 4 die and wire them in series 4S , making it a fairly high Vf - nominal 12 - 16 volts range.
At that point, just use a boost only configuration and underdrive them as needed to deal with real battery capability. (2 x C = 2 x capacity max)
In that case, you can get other drivers from the shoppe or taskled.com or other boost driver options like a boost puck from these guys.
http://www.ledsupply.com/boostpuck.php
I know it is not exactly what we all want, but it does work.
Thanks for the info Harry, maybe it's time to start looking at homebrew circuits again, perhaps things have changed then.
Failing that, I'll also take a look into running a 4 die LED, thanks for bringing up that option as well.
