Hello everyone!
I'm totally new to this forum and am eager to build myself a great light for my cycle. I live in Sweden and the days are getting shorter and shorter. At worst we only have 6h (in the south :P) of daylight per day so good lights are essential around here. :)
I have decided to use 3 x Bridgelux, probably 440lm star neutral white ( http://export.farnell.com/bridgelux/bxra-n0400-00000/led-array-440lm-star-neutral-white/dp/1692080 )
I'm not entirely sure about the 440lm or the 880lm version but I'm pretty sure that 440lm will be enough for me. I'm also not entirely sure about neutral white or warm white. I really hate the blueish white lights that some LEDs have.
The setup I'm thinking of is milling one block of aluminum there one light is focused on the road (to be used both in woods and on roads) and the 2 extra lights to be pointed somewhat straight forward. I have not thought about reflectors yet.
I'm thinking of building the driver(s) myself, I have a lot of knowledge about digital electronics, programming PICs etc, but analogue is my poor side. I want PWM controlled constant power driver. the digital part with pic and PWM signal and programming is no problem for me, but the constant current driver I don't have much knowledge about, tried to find schematics but haven't found any good ones yet. Beet looking at some IC like ZXSC300, STCS1A but don't know how to solve this yet.
The led wants constant current and constant voltage, how do I solve the voltage part? or does the circuit balance itself to the correct voltage when it finds the correct amp's ?
The power source will be a bunch of LiPo (Lithium-ion polymer) cells. They are 3.6Volts 2.6Ah each, how many is not decided yet but I want around 5h of light.
To recap;
* Will I be happy with 3x 440 lm neutral white?
* What type of reflecor(s) would fit and be good?
* PWM Constant current driver? Schematics?
So with your help in here this thread will be a build blog as I progress. And hopefully before it gets too dark outside I will be finnished :)
Thanks a lot in advance :) :cool:
//Daniel
To recap;
//Daniel
