As for the Strion upgrade, I am still smoothing out the kinks in the design. I have to find a way to prevent the danged emitter from shorting out on the reflector base and then I want to see if I can drill out a hole large enough in the reflector (darn you have to keep the reflector its got the threads to the head and body...) to fit an McR reflector. On top of that I need a thinner star board and a regulator board that is equally thin and will fit in the strion (aka a sandwich, but no luck for one that fits totally right). So give me a month or three ( I am a junior in high school so I am wicked busy). Eventually I think I will either utilize an RB80 star or a Seoul P4 Ubin on a star. Both will either use stock reflector with a larger hole or a drilled out reflector to accommodate an McR reflector (most likely McR10 rebel, or 16 seoul.) However, I have been finding that I like the incan beam more than the LED
personal preference, but I will be working on an LED drop in due to efficiency. PM me for further info. Thermal management is even tougher in the strion, has to live on the star board to survive.
