Burned & broke my Fenix PD20 LED
lightnin'hopkins
Hi, I've been a bit clumsy & need some advise.
I need a new emitter on a mounting plate so I just need to solder the wires to the plate.
I think it's a XP-E R2. The plate is 10mm.
Where can I get one or a similar suitable replacement?
And what are the alternatives?
I'm a noob & all the R2 this & Q5 that is really confusing.
Will this work?
"Cree XPE WC-Q5 LED Emitter on 12.8mm Base"
And btw, must be available to Sweden at a reasonable price.
The whole story is kind of stupid:
Was evaluating some battery runtimes in turbo mode with the help of my camera in time-lapse mode.
On the fourh battery, the emitter developed a dark spot on the surface of the glass dome lens thingy.
Had the lamp head covered in bicycle inner tubing & on top of that a big plasic tripod clamp.
25 degrees celcius ambient temps.
Guess that was too much heat insulation.
The lamp still worked fine but a little dimmer & with a oval-ish hotspot.
Anyways, I decided to open it and try to file off the spot.
As I said, it looked to be only on the surface and pretty shallow too.
The PD20 proved to be a complete ******* to open as it had serious amounts of thread glue.
I finally got it opened & while filing, the dome broke & the tiny wires became severed.
Duh.
(Bump & pictures added)
Oh no.
Sunspot.
My poor XPE.
Dent, scratchmark & thread-glue.
What was I thinking? Now I've killed it.
Throwing in a "gee, that looks sad!" (and it really does!) comment to help your thread with a bump to the top again. Maybe you might want to have this thread moved to the Flashlight Electronics or Homemade and Modified Flashlights Discussion forums?
And welcome to CPF!
Too bad you broke the wires. It would have worked without the dome and you would have more throw (but less lumens).
