Re: Burnt E2e KL1 -> FIRE!! ** I FOUND THE HEAD!! **MUST SEE THIS
so surefire CS are not going to do anything about the burned and destroyed e2e?
they should u know. If they can replace a broken light drop from a clift.. due to one negligence, then it should be the same analogy as dropping it in the fire accidentally.
the reasoning of coming to a decision of a replacement due to the light failing from the clift.. or the torch damage in a battlefield is all accidental damage because we as user subject the light to that force. we use them in dangerous situation , odd and weird circumstances that os why we buy them in the 1st place so they are build to last.. in my humble opinion the same should be applied to accidental fire because fire is just a force of damage.. accidental is the catalyst to the force, we as human created that catalyst hence the same analogy..
anyway.. if I were in ur position, I would try to get it replaced at least with a e2e, the KL1 head let it be, a loss. at least u get something back an e2e though without the KL1. I am sure they would appreciate ur reasonableness.
though it might seem as "taking advantage" but not to the obvious extent. Surefire warranty may be seem limited and strict but at the end of the day its still at their discretion, if they replace it, its good if not.. nothing can be done..
better to try than not..
