Hello all.
I've been running a BM S6 dynamo on my commuter bike. I've had a number of lighting setups hooked to the dynamo, must recently a Supernova E3 headlight and taillight. I was bombing down a local hill, when my lights went out! When I went back and looked at my cyclometer I was probably going 45 MPH when the lights went out.
I pulled the dynamo off the bike and spun it with a drill motor. I wouldn't light a known good light. I then checked the resistance and got .2 Kohm and found a max voltage of .2 VAC. Mechanically, the dynamo feels just fine. I'm curious, what is the likely failure mode here? I am considering that the failure might be with the current limiting circuitry in the dynamo.
What do you think? I'd like to repair this dynamo if possible and I'm hoping someone has some experience with this before I start taking it apart.
Thanks,
HB
Thanks,
HB
