formdeformed
- Joined
- Dec 25, 2017
- Messages
- 7
I finally got my new circuit out for its first test ride and thought it would be nice to share it and get some feedback.
It’s a step-down regulator with timing controlled by a CMOS 555. The 555 is setup in astable operation as a voltage-controlled oscillator by placing the two white LEDs at the control voltage pin. Those two LEDs also turn the NPN at the discharge pin on. This prevents the stand-light capacitor across the main LEDs from discharging through the timer chip.
Using the control voltage pin in this way alters the RC charging formula which determines the length of time the output it high. It does not alter the RC discharging formula. Consequently, the off time remains constant and the on time decreases as the voltage increases. Meaning, the duty cycle is high at low voltage ~ 90%, and decreases as the voltage rises. R1 is the main variable. Formulated a best approximation then experimented to determine the best value. 11.25k is a 12k and 180k in parallel. 10k and 12k were both good, but not quite great.
At low speeds the current through the LEDs is the same as a basic 2 LED circuit with the resonant caps. Going faster than the resonant peak around 12-13 mph the timer maintains a lower duty cycle which keeps the current at the peak.
Typically, with the 270uF resonant caps, the current peaks around 0.9-1.0 amp but fades to 0.55-0.6 at 20+ mph.
The results from this circuit.
8 mph = 0.46 amp
10 mph = 0.76 amp
12 mph = 1 amp
16 mph = 1.13 amp
20 mph = 1.10 amp
Measurements are per a Klein MM600 DMM.
I wrote up a lot of explanation that I’ve decided to cut from this post to keep it at a reasonable length. Let me know what you think?
555-VCO-STEP-DOWN-2-LED Schematic
- Cory
8 mph = 0.46 amp
10 mph = 0.76 amp
12 mph = 1 amp
16 mph = 1.13 amp
20 mph = 1.10 amp
- Cory
