C maglite
350xfire
Texas
Was wondering if anyone has the right size for a c mag tailcap o ring to allow to seal the cap for dive light?
Thanks
btw if anyone needs the o rings for a d mag I have some I can sell in small quantities...Custom boro glass lenses coming soon in 5mm thickness!
hmm, might be interested in 1 or 2. is that just flat and 5mm thick or is there some stepped design to be able to screw the bezel on the head properly?
I only have a mag D so can't help with the O-ring.
I think basically you take the same inner diameter but the thickness is one size thicker. What thickness is the replacement o-ring for the mag D that you have?
OK, I'll let you know when I get them in...
O-rings are NBR70 124 for tail and 48mmx2.2 (I think) they are the ones Pack listed on his post a while back.
I'll buy some off your hand. I need enough for 2 mags please. PM me and we can set up a paypal purchase.
I have a bunch of NS latches if anyone wants some reasonably priced.
Im glad you found my post about the O ring size because I couldnt find it.
Could also be interested in some lenses. Are the latches same as the Salvo/ DR ones?
Yeah, I came across it by luck... Don't remember if it was through SODS or where.. I went ahead and bought a bunch since I found some locally.
The lenses will be 5mm boro glass and will sell for $10 each (will drop the price some with a minimum quantity of 5 or so). I will test them as soon as I get them to see how deep they'll go.
The latches are similar except for one thing, they are the uplever type instead of the down lever. I'll sell them for $8 each. Typically they sell for $10-12 each. Includes strike as well. I have just decided to go with the threaded lid design.
I'll be going to the oring place tomorrow to see if I can get the C Mag tailcap oring. Also may try to fab up a tailcap out of delrin to give a better threaded thickness.
