c thread mag, 3 x 18650 tube
David Gretzmier
Springdale, Arkansas
I am looking for an aluminum tube to fit a mag c-size head thread and 3 x 18650 in a tri-bore config. I also need a tailcap with spring that will act as a twisty switch.
Will three 18650s fit in the body of a C maglight? I'm too lazy go go measure it right now.
A head for a C and D maglight are the same size, just different sized bore where the body screws in. That may help if you find the C body too small for the tri- configuration.
Daniel
Daniel
18650 is 18mm diameter, C is 25 or 26mm, and D is 32mm. Even a D body can't be tribored to take 3 18650s across; this needs to be a custom body like an Elephant.
