BC the reason that not drinking caffiene gives you headaches, is the same reason (IMO) that caffiene GIVES people migraines.
caffiene is a diruetic (water remover), and it reduces the size of capilaries, a combination that makes it as addictive as heroine.
you see putting caffiene in your system is toxic, and like all other toxic drugs, your body needs to dispose of it rapidly.
so that means your normal fluids LEAVE your body, and your brain
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
there is this SAC of liquids around your brain, that keeps it from smashing up against your thick skull.
when the diruetics (of the many out there) leech water out of your body , the brain sac is depleated, and your brain gets beaten to death.
Thanks to the caffiene though you dont feel as much, so you dont know its happening.
then it contracts your blood vessels, like the capilaries, so your brain shrinks, and of course because your brain is 99% water it suffers
so when you quit sucking down your favorite PP Juice, and rushing off to the poty, you must replace the liquids you were formerly drinking with water , or other non caffinated, non alcoholic drinks (alcohol is also a brain depleating diuretic).
then you have to give it TIME for the body thermostatic protections to re-balance to the alterations you made, your brain will expand when your not on caffiene.
eventually the brains protection sac will refill, and the brain expansion will reduce, also the cranium containment system is capable of expanding slightly. so you can look like them aliens
its my opinion, some or all of these combinations are what causes the Worst of the migrains. and migrain sufferers often do the worst things to "fix" them they take an asperin, which thins the blood, and stops the brain from knowing it is being damaged.
so generally a migraine sufferer cause it all to themselves, and only takes cheap quick fixes that only make it worse.
so
drink lotsa water, eat bannanas (increase the potassium to reduce higher blood pressure) and stay away from them drugs
what did caffiene ever do for anybody anyways, other than make them believe they were awake for 20 minutes, so they could get to work and pass out. /ubbthreads/images/graemlins/smile.gif
This message brought to you by the Daisy pharmacudical company, offering special prices on drugs that undo the side effects on the drugs we sold you last week
