I would really appreciate feedback, extensions, improvements to the following attempt to produce a replacement for the light's manual. The following is based on my LF5.
BASIC UI HINT NOTES
My camera just died, and this would be hard to photograph anyway because of the angles involved, so please bear with text only:
Changing intensity: P1 and P2
The Liteflux twisty has three positions:
Changing modes (non-strobe, strobe, SOS, etc) - Switches
You change modes by doing a Switch (S) - either a P1-P2-P1 or a P2-P1-P2 twist - i.e. you twist away from where you were and back - in less than a second.
Here are the important things the manual gets wrong or misses out:
Standard mode (non-strobing)
In any mode, do one Switch and the light will go into standard mode. Then:
If you're running on 14500's, which seems to be the designer's intention, then you'll rarely want 100%, so making it the hardest setting to get makes sense.
Strobe mode
To get strobe, do three switches. Then:
SOS mode
You guessed it: four switches. Then P1 and P2 transmit an SOS at two different rate/intensities.
Other modes
The light has a demo mode, voltage check mode, and programming, but you're on your own with these.
I'd appreciate help on adjustable mode and those advanced modes, plus knowing whether the slot thing works for other people's lights as well as my LF5.
BASIC UI HINT NOTES
- OFF - The light is off when fully tightened
- P1 - Untighten slightly and you reach P1. The light comes on.
- P2 - Untighten some more and you reach P2. The light stays on, but does something different to what it did when it was in P1. Depending on the mode, it will strobe at different speed, show a different brightness, etc.
- The manual says that P1 is 1/4 turn from OFF and that P2 is 1/4 turn further on. Wrong! The light comes on with a much smaller turn - about 1/8.
- There's a laser engraved white dot on the upper body of the light. When this points at P1, then P1 is selected; when this points at P2, then P2 is selected. See the next item for where P1 and P2 are.
- Following the manual, you'd think that a Switch is 1/4 turn. Wrong! If you do it between the two correct places it is only 1/12 turn and MUCH easier to do: Look at your LF5. Find the flat part of the tube with the manufacturer's name on it. Rotating in the direction that you use to turn the light on, you'll see two slots. Treat the first of these as P1 and the second as P2. Yes, the light will come on much sooner than you reach the first slot, but this doesn't matter. For purposes of doing switches, these slots are P1 and P2.
- P1 = 50% brightness
- P2 = 15%
- Two switches = 100% brightness at P1 and P2, but blinks once when you switch to P2.
Strobe mode
- P1 = slow strobe
- P2 = fast strobe (15Hz - be careful with this; this frequency is exactly the worst one for photosensitive epileptics and many migraine sufferers)
SOS mode
Other modes
